1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Absurd no manual transmission
  #91
Old 02-08-2016, 08:12 PM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
Originally Posted by Tom
To be fair, most torque converters can multiply torque as much as 2x. So multiply the 3.97:1 first gear ratio of the 6R140 by 2 and you may have an equivalent as high as 8:1.
The current automatic behind the 6.7L can put more torque to the driveshaft unless the guy with the NP435 sidesteps the clutch.
Doesn't this only happen at low RPM before the TC locks up? seems like it would generate an awful lot of heat if you could get up to full torque in a slip condition...
  #92
Old 02-08-2016, 08:14 PM
Tom's Avatar
Tom
Tom is online now
A locked torque converter behaves identical to a clutch that's fully engaged. There's no slip and no torque multiplication; torque multiplication requires slip. It does generate a lot of heat, torque converters are why automatic transmissions require coolers but most manuals do not.
  #93
Old 02-08-2016, 08:18 PM
TexasRebel's Avatar
TexasRebel
Originally Posted by '65Ford
That's true.
Looks like SuperDuty trucks get the 1410 series u-joint which yields somewhere under 3000 lb ft. I don't know how much torque these SuperDuty transmissions are allowing to pass, but just seems to me that something is absorbing some of the power from today's diesels because I don't see how a 1410 joint could take the full power multiplied by a tranny's low gear ratio without breaking...especially if the truck bed is fully loaded and max trailer weight is hitched behind while on dry pavement. That's not to mention the occasional shock of spinning a tire on an icy puddle and then having it hit dry pavement under heavy throttle. Something is allowing some give.
http://www2.dana.com/pdf/DSAG-0200.pdf
Here is what Dana has to say on the subject...
  #94
Old 02-08-2016, 09:33 PM
'65Ford's Avatar
'65Ford
'65Ford is online now
Thanks for the link..I actually ran across that myself. I can't do any of those calculations without knowing how much if any torque multiplying the TC does and how much if any torque limiting the computer is doing in low gear. I'm actually not too interested in doing the calculations. I'm just curious if the computer limits torque of the engine when the tranny is in low gear.
  #95
Old 02-09-2016, 05:58 AM
finn's Avatar
finn
finn is offline
Yes.
That's how the modern high torque Diesels can be offered with the relatively light duty drivetrains availability in pickup trucks.
  #96
Old 02-09-2016, 07:27 AM
'65Ford's Avatar
'65Ford
Makes sense; thanks for the info. Watching the diesel pickup engines evolve over the past 20 years is sort of like an arms race...I'm wondering just how high they'll go.
  #97
Old 02-09-2016, 07:39 AM
Coachhick's Avatar
Coachhick
Coachhick is offline
You're exactly right about the arms race, everytime one adds 50 lb*ft of torque, the others add 60.
Ya'll are talking about the torque converters, but the PCM and TCM severely reduce the amount of torque that is applied in many situations. I don't know what year Ford started doing it (I assume they have), but you CANNOT powerbrake an 07+ Chevy. It's next to impossible to spin the tires even though on an 2001 with less torque and horsepower you can burn 35" mud grips down to the rim.
Even though these engines are capable of producing 7 million horsepower and 9.5 million pound feet of torque, the computer does not allow them to reach their full potential until the vehicle is in a situation that that application of power will not damage the axles, drive shafts, transmission, etc.....X RPM in Y Gear.......(ie at 55 mph when you go to climb that hill with 15,000 lbs) you don't get it all from a dead stop.
  #98
Old 02-09-2016, 01:01 PM
pgg00's Avatar
pgg00
pgg00 is offline
This is why I haven't bought a new truck. That and the crappy plastic interior. Instead i rebuilt my truck instead
davcad
Aerostar
07-26-2019 08:00 AM
mvs4th
2015 - 2020 F150
362
02-17-2017 06:35 PM
mrdlh
6.7L Power Stroke Diesel
26
01-05-2011 08:36 PM
Pud500
04-10-2010 01:22 PM
yukonsly
04-10-2006 06:01 PM
Quick Reply: Absurd no manual transmission
