FMX trans help please
While I know zip about ford transmissions the first thing I would do is disconnect the linkage from the trans and move the selector shaft by hand into the park position. Then rotate a rear wheel and see if it goes into park, if so then just need to adjust the linkage.
If not then the possibly the selector lever or a part of it is not keyed on the selector shaft correctly? The FMX selector looks to be keyed.
I have a 1967 ford ranger 100 that pops into reverse so I worked on colum for hours trying to fix this problem with these fords popping out of park. I figured out detent was not cut right and I finally got mine to click into park like a normal shifter. Colum should lock it and need to know you can't blame it on trans or put parking brake on to fix this old problem. This is the 2nd ford I had that did this and it's not because you need to grind shifter or detent is wore out. Mine locks in by hearing it click into park now and I'm not hooked to trans. If any one is interested I'm going to be making new detent that works for anyone that wants one. Does anyone know if there is one to buy ? If not I will make them and heat treat them and show a video that this works great! If I get enough responses I will make a few up.
Danny, I would like to see yours. I am sure it will help others out!
I am not an FMX expert but if it is anything like the C4 and AOD then there is a lever inside the trans that moves the park pawl...sounds like the lever may not be in the correct position. Some of those linkages are easy to get on the wrong side of the activating pawl. Good luck.
1967 detent
If your column is suppose to lock into park you must fix that first. Your transmission should also click to each gear without linkage hooked to column. When your column locks into to park with a click noise then column is ready for adjustable linkage to be hooked up to trans and do no go under car or truck unless you know what your doing.
I also have an FMX. And it has jumped out of Park and into Reverse all by itself, and the problem is as far as I could tell a weak Park detent lock on the steering column.
I have a 56 F-100, with the factory, original, automatic transmission shift column. On mine there is an "index plate" behind the steering wheel, which has a slot that the shift column interlock mechanism is supposed to lock into when in Park.
Upper pic: 1954/55 / Lower pic: 1956.
Index plate
If your column has a slot in it for every shift position? Then your linkage is not set right or not the right one. You should be able to adjust linkage. Don't be playing around by yourself with this. Is your trans and column a match to make it proper? If it's jumping out of park on that 56? First of all unhook linkage to trans by a professional so you don't get hurt. Shift the column and see if it locks. If it doesn't lock you need that part to make it lock before you rejoin linkage. If you want to know what part locks it, google each part number and you will find that part that locks column into park.
The index plate (i doubt it's the official name, just a descriptive term) I am referring to is the vertically long plate at the end of the steering column. The 7209 shift tube slides into it, and the 3511 flange bolts over it. Sorry if I created any confusion.
But I am sure others could benefit from your solution for their same years of trucks.
Column
. I'm sure by looking at at the older 60s cars detent I can make a detent work on all them. If you did yours I will not worry about producing any. Thanks👍
