A/C and Heater on at the same time
I have a 1999 EB Expedition with climate control system. I am getting warm air from the rear system, but the front is barely warm. I think the A/C is on at the same time as the Heater and is cooling the warm air. It has nothing to do with the blend door it is working perfect. Is there a way to keep the A/C compressor from working without damaging it?
Any help on this would be greatly appreciated, Thanks Carl
If turned on to defrost the a/c will be on but the heat level swivel switch will allow the air to come out very warm, both front and rear.
No and that's something that I find annoying. After all, why should I have to pay (in extra fuel) to run the compressor just because I want my defroster on, or the vent floor position! Not to mention the added wear and tear on the compressor. IMO, all vehicles should have a compressor switch and a recycle air switch...let the driver decide.
My '01 doesn't have an AC button either. I'm pretty sure the only position the compressor doesn't run is floor/vent together, but I'm not certain.
Usually ford has them set up to run without the ac in panel and floor. But, If you select floor/panel split, it will run.
Every ford I've owned without an ac switch has been this way all the way back to my 81 crown Vic.
I'd be more suspect of a malfunctioning valve in the heater hose than anything else. Not sure if yours has one, but i know my 05 does.
I'd start there.
I'd start there.
The air was hot for less than a minute and went to Luke warm still puzzled.
Possible causes, if a wide temp differential is noted, include:
Low coolant
Clogged core.
Other restriction in the heater coolant loop.
Worn out water pump.
Molineguy
09-13-2010 09:25 AM
karljay
11-14-2005 10:08 AM
phantmlord
09-29-2005 12:11 PM
