Please help! Washington State
North West Custom Diesel ? Tacoma, WA
Jiffy Lube would be better (if you don't mind paying) because if you do it yourself you would end up with a couple gallons of toxic (animals love the sweet smell / taste) used coolant to dispose of.
Plus you really should check the coolant mix afterward (Jiffy Lube should do it for you) to make sure it will protect your engine from freezing and cracking something really expensive.
Thanks for your help today, fellows! I managed to disconnect the hose from the reservoir to the radiator and then used a meat syringe to syphon almost 3 qts of mixed liquid/oil from the reservoir, tho it isn't empty yet. I'm not looking forward to sucking on a hose to syphon the rest... But it may be a moot point. I added 2 fresh quarts to the oil intake as demonstrated on YouTube, but oil still doesn't show on dipstick, and exhausts are still billowing white Smoke. I hope and pray that my truck isn't dead in the water!
@Yahiko Is not to far from Tacoma and has some serious 6.0 knowledge as well. Maybe he can assist.
It's easy here too, but people still poison tens of 1,000's of their (or their neighbors') pets or wild animals every year by leaving the pan of anti-freeze sitting around until they can get rid of it.
motor-man
12-21-2009 12:11 AM
