Ford flathead 226 engine stand???
Old 11-30-2015, 01:11 PM
pezsox's Avatar
pezsox
pezsox is offline
I am getting close to taking my motor off of my frame, and I know that many of you have stated they are really heavy to put on a common engine stand. It may be sitting on there for awhile. Any recommendations or fabrication I can do to a common engine stand? thanks
Old 11-30-2015, 01:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Start with a heavy duty, four-legged stand, and make or have made a plate to mount it off the exhaust port bolts. I don't know if anyone makes them for sale, Stumpy's would be a good bet:
Featured Products -
The ones at the bottom are the kind of thing I'm talking about. You can see the official Ford support in the pic below.
I've heard and seen the flat-6's on a regular stand supported off the bellhousing, but it would make me REAL nervous. Once the crank is out, it would be more manageable. I suppose you could make some kind of support for the overhanging end of the block, but it would make rotating the block a pain.
Old 11-30-2015, 02:31 PM
3twinridges's Avatar
3twinridges
3twinridges is offline
The mechanic on this video just used a wood crate to store the engine. Looks like the block and oil pan rails are sitting on blocks on a larger wood pallet. I plan on building this same design only adding castors to the bottom for mobility. He also moves the block around by flipping it by hand. I have been doing the same but with my lift.
Whats the best way to lift these beasts? With the head off and lift bracket bolted in?
JB
Old 11-30-2015, 04:30 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
If you not going to do much more than store the engine for awhile the long furniture dolly some 2x4's and a tie down strap work real well
Be careful with those dollies, before you know it your garage and house will be covered with them
If your going to tear down the motor then go with Joho Nolin's engine stand and Ross's side mount design
Old 11-30-2015, 07:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I haven't ever lifted a 226, but I've done even bigger inlines. I don't like lifting off the block deck directly, too much chance of putting a divit in the surface. The exhaust and intake ports should be fine, if you tighten a flat lifting lug down against the surface. But on the opposite side of the engine, I don't know what you can use. Anything 3/8" should be OK. You could use a choker sling, but I don't trust them. Will you have the front end sheet metal off?
Old 11-30-2015, 08:45 PM
3twinridges
Yes, when I swap, I am swapping and derusting everything up front, including the radiator. I have a NOS three core heavy duty radiator I am dying to bolt in. And plan to change tranny too with the one I am rebuilding. Basically gutting drivetrain and putting in all new/rebuilt/correctly painted parts.
The manual shows a lift plate bolted on the deck. Couldn't I avoid the risks of a divot if I used a piece of thick cardboard in between?
Not doing this tomorrow or even this month, just trying to plan ahead. Right now I am lifting it with a sling through the piston chambers but that only works while I have it taken apart.
Jonathan
Old 11-30-2015, 08:48 PM
3twinridges
And I equally worry about the manifold studs, bending or breaking those. They will not budge and so if I break one its helicoil time.
Old 11-30-2015, 08:54 PM
3twinridges
What if I had a sling in the back around the bellhousing and and two chains up front on the motor mounts, one on each side?
Old 11-30-2015, 09:46 PM
ALBUQ F-1's Avatar
ALBUQ F-1
If you use a plate on the deck, that's a very good solution. What I was getting at is some people stick a bolt thru a chain, and tighten it down onto the deck. The chain can dent the deck easily. A lifting lug that only catches one bolt can also mar the deck. But a longer plate with 4 or more bolts and reasonably flat, tightened down onto the deck, is very safe.
Is there a way to do that with the head on? It would be SO much better to put the head on and torque it with the engine out of the truck.
This is the lifting plate I threw together for flat-V8's. It work off the intake flange. (one bolt is missing, it uses 4) The engine is perfectly balanced with the single hook, with flywheel on. For a flat-6, you might want to use a leveling beam due to length. You want something stout if you're going to lift over the fenders!!
Old 11-30-2015, 10:01 PM
3twinridges
Thanks Ross, when I get closer to the swap I will check that out. That plate is exactly what I was envisioning to do what I want to do. I should be able to torque it pretty well. I torqued the manifolds on with the engine in the truck and it wasn't bad.
Jonathan
Old 12-01-2015, 09:35 PM
Brian~50F3's Avatar
Brian~50F3
Brian~50F3 is offline
For what it's worth, here's my experience... not saying it's the safest or "correct" way, but it worked.
Pulling the engine, two grade 8 bolts, chain offset ot balance, left the head on. Once it cleared the frame, straight down to the trans pallet to remove trans and PP. Minimized any sway and moved very slowly. After that engine whet to it's own pallet where it sat for just over a year
I used wood scrapes I had lying around to make mounts on the pallet for it.
Disassembly; used a four point stand from HF. This was a little dicey... I was uncomfortable enough I moved the pallet under the engine, and placed a cinder block under to help support the end incase something bad happened. Once the crank was out it was much better.
This was the ONLY way I could get the stand to line up with the block...
Old 12-01-2015, 10:10 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Yikes, not good! Really need two above the pivot and two below, especially when you flip it over. It's hard to get that on the V8's too.
Old 12-02-2015, 09:11 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
Received 2,059 Likes on 804 Posts
Here's what I used 30+ years ago when I had the flat six out of my F-2. A couple of 4x4s and sme 2x4s. I built another set up like this for the extra flat six I have n my shop.
Ed Bamba
07-31-2017 11:27 PM
1950FordF1
02-19-2015 11:11 PM
Ed Bamba
01-14-2015 10:30 PM
DRMBailey
02-12-2013 11:00 AM
Myfreeford
08-08-2011 12:43 PM
Quick Reply: Ford flathead 226 engine stand???
