Do I Have A 460??
Old 11-30-2015, 11:34 AM
AKHunter93's Avatar
AKHunter93
AKHunter93 is offline
Do I Have A 460??
Well I bought this engine sight unseen for $100, going on the seller's word that it was a 460 out of a 1996 one ton truck. Upon inspection, I'm not so sue what I have. Hopefully you guys can help me identify it?
Driver side casting, cylinder head
Passenger side, engine block casting
Valve cover? Four bolts? I thought it had seven?
Old 11-30-2015, 12:43 PM
AKHunter93's Avatar
AKHunter93
Anybody? Anybody at all?
Old 11-30-2015, 02:47 PM
mcdonaldm's Avatar
mcdonaldm
mcdonaldm is offline
it's a 460 with fuel injection.
Old 12-01-2015, 02:54 PM
Conanski's Avatar
Conanski
Conanski is online now
On the decal visible in the first pic it's clearly labeled as a 7.5l, and if it does have a fuel injection system on it then it's definitely an '88 or later engine.
Old 12-01-2015, 03:51 PM
AKHunter93's Avatar
AKHunter93
Well look at that, I totally missed the 7.5L on the white label. I was able to find info on the casting numbers that verified the information I was given. Thanks all.
Old 12-03-2015, 09:21 AM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Redneckfordf2502002 is offline
the only thing is those heads are E7TEs which are only on 87-92 trucks. In 93 they got F3TE heads.
Trav
Old 12-04-2015, 02:02 AM
AKHunter93's Avatar
AKHunter93
I've not been able to find any information regarding when the F3TE heads were introduced.
In any event, the engine was either swapped in to the '96, or he didn't realize the truck was older than a '96 when he bought the engine out of it.
Ah well. Such is life. The build continues!
Old 12-21-2015, 09:09 PM
wtroger's Avatar
wtroger
wtroger is offline
The valve cover says it's a 1990 motor
Old 12-21-2015, 09:12 PM
AKHunter93's Avatar
AKHunter93
Damn, I keep missing things in my own pictures.
Does that make it a true 1990 motor? Or was 1990 the last time prior to this engine's construction that it received a major upgrade?
Are there any other significant markings to be found on the engine to corroborate that date?
Old 12-21-2015, 09:20 PM
wtroger's Avatar
wtroger
wtroger is offline
That usually means the year of the motor. The Feds usual change the emission rules every year.
Old 12-21-2015, 09:23 PM
AKHunter93's Avatar
AKHunter93
Makes sense. Does the E7TE casting number on the head corroborate the build date? I've been unable to find a source of thorough information regarding the casting numbers and dates on these engines.
Old 12-21-2015, 09:36 PM
wtroger's Avatar
wtroger
wtroger is offline
No that's the engineering casting number that correlates to the head being design for introduction in 1987
Old 12-24-2015, 09:05 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
The 1990 emissions calibration code tells it was built for the 1990 model year.
It could have been assembled it late 1989.
None of this really matters.
It is a '88-'92 engine.
djc1481
03-29-2019 12:02 PM
jtpasto
02-25-2019 10:30 AM
F460bigbore
20
08-12-2018 09:06 AM
LittleBlue79
02-12-2017 02:26 PM
sleepy_fella
01-18-2011 05:20 AM
Quick Reply: Do I Have A 460??
