Does anyone still put standyne fuel treatment in their trucks? Used to put in every 2 or 3 tanks in my '06 6.0 but don't see that talked about on the 6.7's.
I still use the Opti-Lube product most fill ups. Summer version during warmer months to add lubrication and increase Cetane. Opti-Lube XPD in the winter for same reasons plus anti gel in cold weather.
i use it every tank. Its billed as cetane booster and lubricity enhancer, NOT necessarily as a cleaner as in a typical STP injector cleaner for GAS engines, so if used, it would stand to reason, that it should be used all the time to get the benefits.
I used to use products like this in my old 6.9 diesel, but to date, I have not seen the need to add anything to my fuel with this truck.
I do use the premium diesel when available, but by and large it is mostly #2 diesel that goes in my tank.
I use the Stanadyne Red and Blue treatments. The Blue can be used year round and the Red in the warmer months. I add a bottle ever other tank around home and each tank when on the road.
Since I have a 65 gallon Titan Tank, each bottle is about the right amount per tank.
