Shaving the head
Old 11-29-2015, 06:14 PM
gameover1974's Avatar
gameover1974
gameover1974 is offline
Shaving the head
How much does it cost to make sure head isn't warped?
Old 11-29-2015, 06:22 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Prices range from free if you remove the head and take it to someone. It's an easy check once off the vehicle. You can check yourself if you have a straight piece of glass or steel. Close enough to know at least.
Or $200-300 to have someone pull the head and check it. Getting it back together will cost a similar amount on the higher side of that estimate, plus whatever else needs to be done.
Don't quote me.
Old 11-29-2015, 07:25 PM
timbersteel's Avatar
timbersteel
timbersteel is offline
If pulling the head, just take it to the machine shop and let them send it over for a quick shave. If it has been even once overheated, it will have some slight warpage and the straight 6 heads are known because of their length. If I pull a head, regardless of miles, I make sure its straight by dropping it off for someone to run through for a new shaved, straight mating surface.
DarkStarMedia
02-10-2017 12:12 PM
Cougar54
05-07-2016 10:55 AM
bcford6.9
04-19-2006 10:04 PM
4x4akvan
01-20-2003 10:13 PM
Quick Reply: Shaving the head
