IFS
IFS
i've read here until my eyeballs are protruding. i don't want cv or original axles. i want ifs but i can't get a consensus which is best, heidts, tci, roadster shop, c4 corvette, etc. i want handling comparable to pro touring cars. i'll keep the rear axle but probably 4 link it.
can anyone settle the ifs argument that doesn't have a connection to the companies?
thanks
thanks
thanks
thanks
+1 vote for No Limit's Wide Ride front IFS. Their rear three link is also another great piece. I built my own front suspension for my C10 but wish I had gone with No Limit's IFS.
There was a later model Ranger running the autocross at Goodguys Charlotte this year. It took the truck class win. It had No Limit's IFS.
Youtube video of the Ranger on the autocross:
Don't be misled by the name "wide-ride"...that's just the name they gave the ifs because it's designed for bigger vehicles like trucks rather than a typical mustang II ifs being for cars. I don't recall the actual track width but I'm sure they'll tell you if you call. The website doesn't say although I think it used to and was within an inch or so of the 65-66 track width. Contact them and then let us know. http://nolimitengineering.com/products#!/Wide-Ride-I-F-S/p/26244394/category=6157545
The Jag uses the Chevy bolt pattern 5x4.75. I think the XJ6 from '87 thru '92 or so is what most use.
You should also take a look at the Dakota suspension from Industrial Chassis in AZ. The re-introduction of the Dakota IFS kit It uses 5x4.5 bolt pattern but can also be easily adapted to stay with the stock F100 5x5.5 if you want.
PB Fab - Home of the Original Dropmember
check out these guys
industrial fabs set up looks strong and simple to install
no limit makes good stuff and Roadster Shop stuff is awesome
I have used Morrison, fatman, Detroit speed, Heidts TCI stuff with good results
a friend of mine uses roadster shop stuff exclusively with great success
c5 and c6 vette is great stuff. will require special steering arms but the stock brakes are killer
art Morrison has stuff to fit new vette suspensions up correctly
It all depends on skill level or check book
here is some more less expensive stuff that requires more fab skills
Paul Horton's Welder Series
While I agree the Roadster Shop ifs is top notch, I think you need to doublecheck your research on the others. RS and Detroit Speed (on par with RS in my view) are both corvette based designs using vette spindles, rotors, etc. No Limit is not MII but rather GM based ('79-'81 camaro spindles) and is very stout. Porterbuilt is not MII either but rather Chevy C10 truck based. The industrial chassis unit is also very stout and is a dodge Dakota based design. The only MII based ifs I like is the Fatman unit but if you ever look at one in person you'll quickly realize it is very beefy as they use large diameter tubing for the arms and actually have their own beefy design spindles made to an improved spec. Heidts and TCI are MIi based I believe. Morrison has a few versions with their top of the line being vette based also. Check out the Detroit Speed XGen 595 unit which is a universal ifs someone with good fab skills could install in our trucks. Even though they don't have a custom crossmember specifically for our trucks, Roadster Shop has their Fast Track universal ifs that could be fab'd into a '65.
x2 on roadster shop stuff being great
Art Morrison can build a custom chassis as well even though it isn't listed
they have also built c5-c6 vette installation components for a shop I used to work at
you can order a front suspension based on track width and components from several of these companies, then build the rest
JonTaco
03-22-2017 01:00 PM
airharley
02-13-2007 06:13 AM
bluespark11
12-22-2003 06:29 AM
