OEM Steering Box Adjustment (w/downloadable Ford pdf)
Thanks to Sean (wpnaes) I realized this has been missing from the tech folder. I coulda swore these instructions were there for years.
Oh well, the oversite has been remedied.
Locate the Allen bolt and lock-nut on top of the steering box. The steering box is close to the radiator. The lock-nut should be a 5/8".
Mark the Allen bolt so you’re oriented and know where the starting point is, then loosen the lock-nut. Turn the Allen bolt clockwise a quarter turn to tighten the gear mesh. Tighten the lock-nut and road test your vehicle.
Be careful not to over-tighten the Allen bolt. If you do, the steering may become tight and stiff during a turn with a noticeable lack of a return-to-center feel, possibly causing you to drive off the roadway.
Keep repeating the sequence, turning the Allen bolt a ¼ turn at a time, followed by a test drive, until you're satisfied with the performance. If you over-tighten the Allen bolt, turn the Allen bolt back a quarter turn, counter-clockwise.
There is a risk of over tightening the box and causing it to wear out prematurely, so I suggest you tighten it to the point where the slop is gone, and no further.
Most people will turn the Allen bolt three-quarters of a rotation to one-and-one-half rotations before they’re happy with the results.
Stewart
Stewart
Stewart
keep in mind it isnt just the gears that wear but also the bearings the main and sector shaft ride on, so the more you tighten it the more off center those shafts are going to rotate off the center of their access. end result, everyhinh is going to wear quicker and eventually just fail. hopefully the seals leak all the oil out rather then binding the gears.
weekendwarriorfsw32
12-02-2010 06:44 AM
jetjock16
1999 to 2016 Super Duty
01-09-2005 11:02 AM
