Centering F1 Brake Shoes
Old 11-28-2015, 10:28 AM
1950FordF1's Avatar
1950FordF1
1950FordF1 is offline
I installed two Napa 4401455 front brake drums. One drum is rubbing against the backing plate on turns. I rechecked the assembly and all seems to be tight without any play. I removed .020 from the inside rim and reinstalled it. Haven't driven it yet to see if it is cured.
As I was re reading the shop manual I noticed I omitted the step for centering the brake shoes. This step requires inserting a feeler gauge through a slot in the drum, this slot is non exhistant on the Napa drums.
Q: is there another method for centering the shoes?
Q: anyone had a problem with drums rubbing?
Q: who makes OEM drums?
Old 11-28-2015, 10:40 AM
f5fordgirl's Avatar
f5fordgirl
f5fordgirl is offline
If the drum rubs the backing plate during turns, it sounds like loose bearings. As for centering the shoes, the springs are what do that.
One Sock
05-30-2023 08:42 AM
3twinridges
08-13-2017 07:52 PM
andy0812
09-03-2012 01:24 PM
tlb
Ford Truck Parts for Sale
04-30-2011 06:00 AM
drew96
04-20-2006 09:48 PM
Quick Reply: Centering F1 Brake Shoes
