1969 Ford HemiFlathead thingie
I believe that this engine at 2.3l is based on the Ford V8 60hp 139ci approx. The cylinder heads were originally designed as Adrun heads for the 239 ci engines in garbage trunks in Eastern USA to give them more power. The hot rodders picked up on them and an original set is worth a small fortune. They were/are being reproduced, but they were still very expensive. They are with out a doubt very stunning in appearence and in performance.
Bruce
Bruce
You can't have it both ways. It's no longer a side valve (flathead) engine if the valves are in the cylinder head. It then becomes an overhead valve (OHV) engine, with a hemispherical combustion chamber in this case. Not a monumental task, but undoubtedly saved a ton of retooling. Don't forget that there were also aftermarket OHV kits for the Model-A engine.
They are Ardun heads, named after Chevy guru Zora Arkus Duntov, manufactured to cure common overheating problems in work trucks, later someone found out since they are Hemi -Heads, they made some awesome horsepower. They are being reproduced, with stronger, better parts by a company in New York I believe, and yes they are expensive. I could buy a crate motor Hemi for the same price !
stone_cold_jo
23
01-24-2019 04:24 PM
