Used engine oil flush and now the engine died (Now fuel related)
I used an engine flush because my engine pressure was low, while the engine was hot as advised in the bottle, and after rolling for 10 minutes (a couple of minutes from my home) the engine died, no noises or signals, it just hesitated and died, then it would start, run poorly and die again. Changed the oil right there and there was no change. So, did my engine break? Or is there anything I can try?.
You ran it with no oil? Just the flush fluid in it? Eh... I dunno about that, I don't believe in using snake oil unless the motor is otherwise junk to begin with, but generally unless an engine is completely seized it will still run even if the bearings are wrecked.
If it runs poorly and dies again I suggest checking fuel pressure first. Then spark, then ignition timing (may have a bad PIP) in that order. It might well be that you just so happened to develop a problem unrelated to the flush right after you did it.
If that all ends up being okay then I would do a compression test, no telling what that flush stuff did to your cylinder walls and rings. But save that for last, I'm leaning towards the above scenario (coincidence) first.
How does it run poorly? Steady dead miss on one cylinder? General misfiring? No power? Smoking?
Received 3,102 Likes
on
Well, I decided to check fuel pressure on the rail, and there was absolutely none, so there was my problem. Checked the Maxi fuse for the fuel pump and gladly it was busted (better this than the engine for sure), replaced it to no avail, so I guess it's time to replace the fuel pump, which seems to have shorted. Meanwhile I'll also replace the fuel filter, to service the whole system.
This may not help you now, but maybe someone in the future. My 1st boss when I started working when I was 13-14 was an absolute savant with all things combustion engine. They truly don't make people like him anymore...anyway, he'd always shudder when someone would mention engine flushes with over the counter products, which are basically kerosene or diesel fuel. A finely-tuned engine DOES NOT like this! He'd always suggest that if you really had to flush the engine (which most engines rarely require) was to use a name brand ATF fluid. Remove about 1 qt. of existing oil and replace with the ATF. Run the vehicle for 500 miles or so, then change it out with fresh oil.
ATF is super highly detergent and will remove whatever you're trying to remove without introducing kerosene into your system (now I just shuddered, lol).
Kerosene is meant for cleaning parts on a bench, but certainly not made to run diluted in your engine. Hope this helps!
Roger
Roger
on
