Light the way? New Headlights?
#77
Is there such a thing as 55 or 65 or 75/100s so you low is socially accecptable but the high is pretty damn bright?
#78
#79
http://www.ebay.com/itm/like/121685454084?ul_noapp=true&ul_ref=http%253A%252F%252Frover.ebay.com%252Frover%252F1%252F711-117182-37290-0%252F2%253Fmtid%253D1588%2526kwid%253D1%2526crlp%253D53601919689_324272%2526itemid%253D121685454084%2526targetid%253D154774705449%2526rpc%253D0.14%2526rpc_upld_id%253D59811%2526rlsatarget%253Daud-151107828969%253Apla-154774705449%2526device%253Dm%2526mpre%253Dhttp%25253A%25252F%25252Fwww.ebay.com%25252Fulk%25252Fitm%25252Flike%25252F121685454084%25253Flpid%25253D82%252526chn%25253Dps%2526adtype%253Dpla%2526loc%253D1023191%2526poi%253D%2526campaignid%253D239125209%2526adgroupid%253D14978428809%2526gclid%253DCLr2w4LwzMkCFckYHwodlD8FfQ%2526srcrot%253D711-117182-37290-0%2526rvr_id%253D946516641312&chn=ps&lpid=82
#80
Anyone tried LEDs yet? They claim to be brighter and would lower the amp draw. There are a few different vendors out there. Here is a set from SuperBright.
jrc
#81
Thanks Nick, I gave it a read. I guess I was exploring the option of HIDs but I dont need to overcomplicate things.. Id really just like some brighter traditional bulbs like the ones I posted. I was curious about whats actually legal and from what I understand 55 or 65w on lows and I didnt see anything for high beams. So, technically with those Hellas 80/100w i'd kinda be on the other side of legal, not that I'm mister by the book but just sayin... I really havent done a ton of research on those harnesses posted earlier. Brad said that one Putco was kind of a POS; I wonder if I could just use those pigtails( 9007 Heavy Dury Wiring Harness | Plug & Play Headlight Wire Upgrade 9007 do I need a kit w relays like this one?
https://puredieselpower.com/ford/900...ml#/product/70
Also, I havent polled anyone yet so for those of you subd to this thread; have you had and headlight or headlight housing heat related heat issues with the OEM housings when going to a brighter/hotter bulb like those 80/100s?
Even a cheap relay setup is better than the stock setup
here is a Good harness nut not cheap http://www.ceautoelectricsupply.com/...relaykits.html
REAL Hella relays(not chinese knock offs), heavy wiring and quality plugs
#82
Those pigtails do absolutely NOTHING. If anything they HURT performance because they just add another connection and ad more length to the wire. Even a cheap relay setup is better than the stock setup here is a Good harness nut not cheap http://www.ceautoelectricsupply.com/...relaykits.html REAL Hella relays(not chinese knock offs), heavy wiring and quality plugs
#83
#84
Thanks Brad, I wondered what good those pigtails were. I thought the same thing. I just ordered that harness you linked. So, you think the Philips bulbs or the Sylvanias?
Also, just out of curiosity whats the risk of heat damage if any to the OEM housings and reflectors with any of the brighter/hotter bulbs such as the Hella 80/100s, the Philips Crystal Vision/Extream Vision, or the Sylvania Silverstars?
Update: I spoke with a Fella who owns a racers supply store in RI, he said they have been carrying Hellas and PIAAs for years as well as new to them Putco and Atomic LEDs. We spoke at length and he appeared to be well versed on auto lighting. I settled on the PIAA extreams since I've already ordered the harness.. Well, I'm commited now. I'll let ya know how it works out..
#85
I have had very good results with the Phillips. I have had Many blown silverstars
PIAA is a Very Good light
#86
On what truck? The OBS or my 6.7? The OBS has a straight wire harness that I Bought from CT Performance (all plug and play, pretty nice). As for the 6.7 I have no idea what I'm going to do to that.
I know Cary at CT Performance either has a guy or Cary is doing them himself, but converting Ford Factory housings to HID. Suppose to be WAY better than the China made ones.
#87
I know this is an older thread, but since I just did the housings on my truck - I got CAPA certified replacement housings with bulbs and adjusters that looked as quality as the original factory pieces for $35 each from Rock Auto online. The bulbs are basic bulbs, not super bright, but the housings and lenses are real nice. I figure now that I've got good lenses and reflectors I'll upgrade the bulbs and wiring harness next fall when we go back off daylight savings time.
stylin86f150
30
03-26-2010 03:03 PM
nighthawk285
33
03-29-2009 02:06 PM
