New Headlights??
New Headlights??
Looking to put a new headlight setup on the 94 but not sure what to buy.
I still have the stock headlight set-up. Sometimes, if the moon is bright, it's brighter than my headlights.
I would like something that looks trick but also will really light my way.
Anyone done a complete headlight swap upgrade? Have pictures? Where did you buy them? Use LEDs?
Thanks guys!
Thanks guys!
There are a few good write-ups on using relays to make your headlights work like they should have in the first place, which is one of my next things to do.
Outside of that I can't tell you much, except whatever you do, AIM your lights properly! Nothing worse than some idiot pickup/jeep driver that isn't smart enough to aim his brighter-than-the-Sun LEDs at the GROUND instead of up in my cab
Are the lenses and reflectors in good shape? If not even factory style replacements would make a big difference. Search on here for the headlight relay mod, it's quite cheap, relatively easy to do and makes a big difference. Depending on what's in your truck now a good quality replacement bulb could also help.
If your driving on a lot of highways and back roads with not a lot of traffic adding an aftermarket led light bar would make a big difference. I've had good luck so far with generic led lights of EBay for reasonable prices. Obviously this option doesn't work so well if your driving in populated areas.
As far as fancy aftermarket lights that replace the factory headlights go I don't know a whole lot.
Received 3,090 Likes
on
I really wish there was some enforcement of bright headlights. I have awesome night vision so I'm continually blinded by oncoming traffic.
With that said... I'll agree adding the headlight relay mod made a world of difference with my '88. That and cleaning up the lenses with one of those headlight polishing kits helped a lot. And please make sure your lights are properly aimed.
on
You could always add some LED fogs or something if you're only having issues on the back roads. A lot of the LED bulbs really suck, but if you get the right ones, they're amazing. I had a friend install them, and I thought he had done an HID swap! They're really nice as they're brighter, but won't blind people like those jerks who put HIDs into their regular reflector housings and blind everyone.
I was in the same boat as you with the lights. Polishing didnt do a whole lot. So i went with something like this 1992 1996 Ford Bronco F150 F250 F350 "Factory Style" 6P Corner Bumper Head Light | eBay
MUCH better even with the stock bulbs. Quality is as decent as you can expect for chinese. I thought i could do even better with HIDs and projectors. $400 later, the projectors are marginally better than the chinese housings. Also, they are DOT approved, they have the stamp on the lense even. They have a very nice flood quality, and dont blind enemy, i mean other drivers. Lemme see if i can dig up some pics.
The only one i have saved to my albums here, unable to get on facebook currently to get the others.
Bright Lights = Bright Nights.
I went with Recon for all mu lighting needs when i got my F350.
The headlights are awesome when you switch out the bulb in the projector to a HID. Lots of discussions on the HID vs newer LED.
I recently switched my 35w HID 6000K bulbs to an equivalent in LED and was extremely disappointed. I switched back to HID.
If i had my time back i wold have went with the 55w HID ballasts and bulbs.
I also installed a 24" LED Light bar from Recon in the lower Air Dam. What a complete disappointment. After running the truck with it for 5 years and making excuses that the HIDs were out lighting it. I replaced it with a Rough Country 24" LED Light bar.
What a difference. The new light bar washes out the HID's. Then above and below the Ford badge in the grill I dremmeled out the black plastic grill to install an upper and lower 30" light bar from Rough Country. Everyone comments on how sick it looks.
Me im blown away by the light when im off road on an oilfield lease.
Icthus in AK
6.7L Power Stroke Diesel
32
11-03-2014 07:31 PM
