Truck wanders left to right
I have 2 F-350 4x4's and they both wander back and forth when driving. They feel like they don't have enough caster.
One is a 2000 V-10 extended cab with 8 foot bed. The other is a 2015 6.7 diesel crew cab with 8 foot bed.
I have driven the 2000 for so many years that I have grown use to the very slight sawing of the wheel to keep the rig straight. When my wife got her 2015 it does the same thing. The 2000 is leaf spring and the 2015 is coil spring. This bothered me when I first got the 2000 (used) but I just figured it was part of the charm of a big truck.
I know I could put a caster shim in the 2000 but there must be a better way to solve the problem.
Both are stock, no lift and no heavy winch or stuff.
Any ideas would be great.
thanks
thanks
I would assume the 2015 has a warranty and would take it in and have it looked at, the 2000 just might need a redhead steering box to replace the old steering box.
https://www.ford-trucks.com/forums/8...installed.html
Red-Head Steering Gears - Custom Rebuilt Steering Gear Boxes in USA
My 14 cclb is the same way. I had it aligned at a friends shop at 3000 miles as it was cupping the tires already. The toe was out and the caster was barely out of spec. I lifted it shortly after and everything remained the same. You can try a set of caster bushings to push the top of the spindle back but it needs aligned to know where you are at. If you are cupping tires you could probably try a set of 2 degree bushings and see if if helps. I'm going to guess if the dealer aligns it and it's in spec they won't make any changes reguardless of drivability.
