Fluctuating gauges:
Old 11-26-2015, 04:22 PM
leonharu's Avatar
leonharu
leonharu is offline
Fluctuating gauges:
My 1973 F-100 instrument gauges are fluctuating slowly.Would this be the instrument cluster regulator or the backing plate?Should I just replace both of them while I have dash apart?I notice my temperature reads higher and the oil pressure reads higher at the same time and then sometimes they read back to the lower side?Has anyone had this problem?
Old 11-26-2015, 06:53 PM
Blue and White's Avatar
Blue and White
Blue and White is offline
It sure sounds like the voltage regulator is going out. Slight chance it could be a dirty ground also (mount screw ground? I've forgotten). I'd clean ground points first and re-check... then replace the IVR.
Old 11-29-2015, 05:51 PM
twozzie's Avatar
twozzie
twozzie is offline
I have the same issue on my 79 F100. The oil pressure gauge is up and then its down. The temperature gauge is up and then its down. Fuel Gauge works fine though. ALT Gauge may be a tad iffy. Guess its time to check all connections etc and maybe see about the IVR (where it is and what it looks like )
Old 11-30-2015, 04:53 PM
Sick6's Avatar
Sick6
Sick6 is offline
Haven't had a Ford truck that didn't do it, varies with voltage and gauges seem to work off each other a bit...Until the 90's when they started using preset oil pressure gauges that read just past half way if you have any oil pressure.
three on the tree
45
10-14-2016 10:27 AM
1972RedNeck
03-22-2015 12:07 PM
JBronco
1978 - 1996 Big Bronco
07-06-2007 12:31 AM
Oleblue74
08-13-2005 11:54 PM
djtdaveboy
10-25-2003 06:26 PM
Quick Reply: Fluctuating gauges:
