1950 magic air heater control restore
It's getting cold and my heater controls were a pain and in bad shape so this morning I set out to restore them. One at a time I took them out, soaked them and the hardware in prep and etch. Then wire wheeled them, soaked in kroil, then sprayed with silicone lubricant. I had found ***** identical except they had H on them. I buffed that off, heated the end of the metal shaft with a butane torch, then forced the **** on. Reinstalled everything once they cooled and they are as smooth as butter!
JB
JB
Looks like this is the one.
Hot Water Heater Defroster **** | Dennis Carpenter Ford Restoration Parts
I think I picked them up at a swap meet several weeks ago, can't remember. They were in a DC bag though, unfortunately I tossed the bags after I buffed them. I think early ford also has them, they are in the car section. I don't think mine had def, just a red h. They are perfect matches and look fantastic I have to say myself. The action on the cables is also perfect, just the right tension.
Don't give up on the buffing either, the writing will come off. I used the small buffing pads from HF and car cleaner wax. If you go too fast you will deform and pit the ****. So slow and steady.
Also get the shaft just hot enough but not too hot. The object is to get it just hot enough to form the plastic on the grooves of the shaft then quickly cool to have a permanent hold.
Also, the tail lights on the '48-56 panel trucks are the same as the '41 car.
Nice job on the heater panel. If you want paint it hammer tone gray paint is pretty close to stock color and texture.
Ford was frugal, they used parts from previous years. The stock radio ***** for the '48-50 truck radios are the same as, I think, the '41-42 car. The only difference is the "flower" dial behind the volumn and selector ***** are clear on the car and brown on the truck which a can of spray paint takes care of.
I may do that when I do a coolant flush and can take the whole unit out. I did find a new badge but am in the middle of planning a rewire adding turn signals and rebuilding a transmission so I need to keep my open project list managable! LOL, our never ending struggle...
By the way to all I remembered while hunting this afternoon I picked up the ***** from Bob at Half Ton. But they are from an earlier Ford car as you say.
thomasstemmle
11-26-2016 04:34 PM
HILLBILLY BOB
02-04-2015 09:57 AM
F-100CustomCabTBC
01-19-2013 06:49 PM
wallster
44
05-12-2012 12:51 PM
