Leaking shifter
Old 11-26-2015, 04:06 PM
mike85120's Avatar
mike85120
mike85120 is offline
Leaking shifter
I am hoping that someone on here will be able to help me on this problem.
About two years ago I had a new engine installed in my truck along with a Tremec TCET-5008 five speed transmission and the Tremec TKO 500/600 shifter.
My problem is that the shifter has always leaked at the top where the shift lever connects.....does anyone know how to fix this problem?
Thank you for any help.
Mike
Old 11-26-2015, 06:37 PM
Rimrock F1's Avatar
Rimrock F1
Rimrock F1 is offline
Mike
Mike, I did a search and found a couple things, links below. Some of the Mid shifters had a problem leaking and there is a seal for it. Earlier transmissions had a vent buit into the shifter seal so overfilling could cause a leak.
tremec/w midshift is leaking, Please help. - FFCars.com : Factory Five Racing Discussion Forum
Tremec 3550 Five-Speed Transmission Rebuild - Modified Mustangs & Fords Magazine
Will Chiello
11-18-2011 09:41 PM
The67Beast
07-27-2005 09:51 PM
fordnut71
07-27-2003 11:29 PM
Quick Reply: Leaking shifter
