Weeping freeze plugs
Oh I should elaborate, I don't want to put something in the cooling system I want something I can use on the outside to seal the freeze plugs. Cooling system stop leak is the reason I'm in this position. The previous owner put in more stop leak than I ever thought possible. I've flushed the cooling system 6 times and I'm still getting stop leak out of the engine. I think the freezer plugs are weeping because of all the cleaner I've used. I was told that stuff doesn't do the sealant on the plugs any favors.
Big blocks don't cry
You need to find out what is making them weep. Perhaps they were maltreated or abused by a previous owner.
Maybe they feel that they are really male plugs trapped in female bodies and so are having a gender identity crisis.
Constant weeping from the engine should never be ignored or belittled as it can lead to resentments and lost trust between the two of you. Let it know you love it and that you will help it through this crisis whether it be feelings of hurt or a voyage of discovery of its true gender identity.
All the best to you two, I know you can patch things up.
