Broken Thermostat Heater Cable for 1983 F-150 4.9L w/o AC
I went to crank the heat up in the old Ford and it gave some resistance from cold to hot... long story short is that I heard a small snap and the heater cable has become detached from the control module (behind the dash).
I am assuming an easy fix, but trying to find the cable is a mess. LMC has it for an 80-82 and reading other post, they change the cable three times in three years.
Any thoughts?
- Eric
Any thoughts?
- Eric
This will not help in locating the replacement part, but in order to have heat, this "fix" might buy the O.P. some time... it seems that some time in the past, a similar post found that "to make it work", a replacement lawn mower throttle cable was made to work by attaching the mower throttle lever to under the dash and routing the cable appropriately?
bobpfister
13
10-02-2012 05:08 PM
Twistedwrench
09-16-2012 08:12 PM
1984_355w
07-21-2003 10:25 PM
