IPR dropping Help
Old 11-24-2015, 05:20 AM
Will Bite's Avatar
Will Bite
Will Bite is offline
IPR dropping Help
Starting to drop at idle to 20%
Old 11-24-2015, 05:29 AM
Will Bite's Avatar
Will Bite
23-24% last week ran fine. Started truck this morning now its at 17-20% idle is up and down.
Old 11-24-2015, 05:53 AM
Will Bite's Avatar
Will Bite
KOEO
Old 11-24-2015, 05:56 AM
Will Bite's Avatar
Will Bite
HPOP at 4050 and ICP volts 4.1, IPR at 80% at full throttle.
Old 11-24-2015, 08:26 AM
cheezit's Avatar
cheezit
cheezit is offline
Its colder out side, the oil is thicker. Worry when it goes the other way.
Old 11-24-2015, 08:35 AM
Will Bite's Avatar
Will Bite
I'm glad it was you that chimed in. It's never done this before running 5w40. This was at operating temp.
Old 11-24-2015, 09:28 AM
cheezit's Avatar
cheezit
cheezit is offline
If you have no other concerns its normal. When you have leaks ipr% will tend to be higher then expected.
You dont say what year the truck is however.
On the idel issue first thing is disconnect the icp and see if it gets corrected.
Remember ipr is the action the pcm is commanding, icp is the result of the command.
Ipr is no more then a metered oil leak from the high pressure pump back to the main sump (oil pan)
Old 11-24-2015, 09:36 AM
Will Bite's Avatar
Will Bite
Truck is a 2006. Truck would almost stall driving home this morning. If I coast IPR would drop down to 17 -20% and would run like it had a miss or was going to stall. Strong diesel smell and white haze when warming up but I just figured it was cold outside. Something is wrong with it. I watch everything close and it's off.
Old 11-24-2015, 09:52 AM
cheezit's Avatar
cheezit
cheezit is offline
Great info. So now we know what your chasing.
Check ficm voltage.
What is eot and ect while its going on?
Try disconnecting the icp. To see whats going on.
Try disconnecting the ebp as well.
Old 11-24-2015, 10:05 AM
Will Bite's Avatar
Will Bite
Check ficm voltage.
FICM volts always good 49.5. It seems like the truck is having a harder time getting up to temp even though I'm running a mishomoto 200 deg stat. Didn't have trouble last year. I might point out that I'm running Matts 8k tow tune but have been for 3 years. It worried me enough this morning on the way home that I didn't stop for my coffee.
Old 11-24-2015, 10:07 AM
cheezit's Avatar
cheezit
cheezit is offline
How are you check voltage?
Have you checked it at 2k rpm in neutral?
Try the other items as well.
Try pluging in the block heater as well.
My guess is a stiction issue but not completely sure.
Old 11-24-2015, 10:08 AM
Will Bite's Avatar
Will Bite
KOEO after a 20 mile drive home.
Old 11-24-2015, 10:12 AM
cheezit's Avatar
cheezit
cheezit is offline
Koer is when you have the concern. Dont assume it's not droping out
Old 11-24-2015, 10:13 AM
Will Bite's Avatar
Will Bite
It's plugged in at home but didn't have one at work. I use my Torque Pro for everything. What do you want me to check at 2k in neutral and at operating temp or cold start.
Old 11-24-2015, 10:19 AM
Will Bite's Avatar
Will Bite
If your talking about the FICM it was replaced 2 years ago it's Ed's. It's always been solid starts at 48.5 and will hold 49-49.5 when driving.
Quick Reply: IPR dropping Help
