1997 F350 CCLB Dually (2wd) conversion to 4x4
Researching 4x4 conversion of my '97 crew cab dually. Can someone give me a ballpark cost of parts to do this? And a sense for how many gazillion hours by a decent wrench to make it all happen? Lastly, any sense for increased value of a well-done 4x4 conversion on what was 2wd from the factory? Truck is very clean and stock in virtually all other aspects. Thanks.
If done properly nobody would really be able to tell it wasn't 4wd aside from paperwork.
The best way would be to have a parts truck that is 4wd. Then you can pull all the odds and ends off. Wouldn't be too intensive besides swapping the transmission. Front axle swap is easy, throw on an rsk with some SD springs and get a better ride and level it out at same time.
Or you could swap to 05+ axles and get coils on the front. Depends where you're at. Theres a complete 08 ish F350 srw 4wd frame complete with axles by me for cheap
Year range is really anything 80-97 for the F350. 99-04 Superduty F350 axle and springs can fit with an appropriate RSK. An decent rsk runs about 400 and springs the same new or can be found locally.
Just nite if you get the 99+ stuff you'll want to swap the rear axle too as the lugs switched to a metric pattern.
For-mins
04-08-2018 02:02 AM
Irish19614x4
20
01-30-2016 06:01 PM
Dugs64Dump
22
04-30-2015 12:08 PM
