89 vs 97 engine harness wiring
Old 11-23-2015, 12:35 AM
97Fordf35089f250's Avatar
97Fordf35089f250
97Fordf35089f250 is offline
I need to know how many wires are on a 97 f350 engine harness plug. And the colors after fuze box under hood then a 89 amount of wires and colors for same motor it's like 4 plugs for 89 but no fuze box same engine 351w I want to swap the plug to fit older engine in newer truck I don't hv money to buy new harness if it plugs in same sensors what's difference 97 harness is too hacked
Old 11-23-2015, 10:17 AM
Conanski's Avatar
Conanski
Conanski is online now
If your '97 harness is complete you don't need to swap anything just install the motor and plug in the wires.
Old 11-23-2015, 01:47 PM
97Fordf35089f250
Yes it runs but has bad head gasket but things different like distriburator wires and has more stuff on top and it's hacked with terminals were he broke plugs I might just use the m50d if I'm easy on it it should work and hold up cause that's were wires are different between manual and auto according to haynes
97Fordf35089f250
02-12-2016 09:50 PM
radramrod2
01-31-2005 05:01 PM
derfixr
08-21-2004 03:50 PM
eazye727
3.8 & 4.2L V6
04-06-2004 11:19 PM
JMR
10-02-2001 11:49 PM
Quick Reply: 89 vs 97 engine harness wiring
