Here's how to replace your Super Duty cruise control servo for cheap! - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-22-2015, 08:33 PM
dexterous dexterous is offline
dexterous is starting off with a positive reputation.
Disclaimer:
Before anyone asks, I am not selling cruise control servos, I am simply a forum member who figured out a cheap way to fix my truck. Further, I do not endorse ebay or any of their vendors. I would also like to add that everyone should do their own research and that I am in no way responsible for anything that goes wrong if you decide to try this!
Any way, I have some good news for anyone who needs to replace the speed control on their early model, gas powered Super Duty truck! I recently discovered that the cruise control on my 1999 F-250 Super Duty V10 wasn’t working. After looking into it, I found that the cruse control servo (A.KA. "speed control servo") was seized up and needed to be replaced. Unfortunately, buying the “correct” servo was going to cost over $430 which really wasn’t an option for me so I started looking at alternatives.
Armed with several years’ worth of factory service manuals and wiring diagrams, I determined that the 1999 SD speed control servo only differed slightly from trucks up to 2002. I also discovered that the newer style servo was used on several 2000+ model year ford cars. Since the “car” part could be purchased for less than 10% the cost of the “truck” part, this was clearly attractive to me.
After swapping everything around and verifying that it works, I am pleased to confirm that part YF1F-9C734-EB which was originally for a Ford Taurus 3.0L 2000-2003 will work perfectly in a gas powered 1999 through 2002 Super Duty truck! Its very possible that this also applies to trucks newer than 2002 but I have no way to verify it. Since there’s very little info on this subject, I created the following video to detail the swap. Enjoy!
Old 11-22-2015, 08:39 PM
Here's the exact auction that I used in the video: Ford Taurus 3 0L 2000 2003 Cruise Control Servo YF1F 9C734 EB | eBay
Old 11-23-2015, 12:18 AM
noober0x noober0x is offline
noober0x is gaining momentum as a positive member of FTE.
Think I can do something similar where I get a $350 ford Taurus engine to replace my 7.3L diesel engine when it finally goes? I mean if you could do it with cruise control servos surely you can do it with engines.... :P
Good video. Good "hack." many simple-function parts are all the same across most cars of similar eras, so there's bound to be others like this.
Old 11-23-2015, 08:13 AM
DavidB DavidB is offline
DavidB is gaining momentum as a positive member of FTE.DavidB is gaining momentum as a positive member of FTE.
Excellent information and video.
Reps sent.
Thanks
Old 11-25-2015, 07:06 AM
LOL, you would need like three motors! Perhaps one under the hood and two in the bed???
Cruise control servo for cheap Odieds69 Excursion - King of SUVs 4 04-13-2016 09:52 PM
Cruise Control Servo Interchangeability 63 Coupe 1999 to 2016 Super Duty 7 11-22-2015 08:57 PM
Know your IDI History, Ford Diesel - 101 mos68x Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 04-08-2015 01:11 PM
cruise control servo interchange question Seitz372 1987 - 1996 F150 & Larger F-Series Trucks 1 03-30-2013 10:26 PM
Did you hear about the new 6.8L V10 Rosson03 Excursion - King of SUVs 37 02-18-2012 07:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
