ID This Trans
On the F3 there are 10 or 11 leaves in the rear spring pack, it'll do just fine with the spring perch shifted 3/4". It's basically a solid mounted axle
The transmission mount is symmetrical, the rubber block that is bolted into the bottom of the transmission crossmember will fit either way. If your wheelbase is not 122", I would say that the rear axle mounting is the problem. You might check to see if the spring center bolts are sheared and the axle is moved forward.
Here's mine right before the trans and diff swap. Notice the rear part of the shaft slip joint is toward the front. Yours is toward the rear.
Not that it matters. The shop that did mine put it on the rear like yours. My point being, maybe the PO had a repair or new shaft made and measured wrong? Didn't allow for slip joint?
Not really, Better to put it back the way the factory intended it to be. You start changing something to out of spec it just snowballs. Much more likely it is just the wrong driveshaft or possibly tranny. I can take a look at it Sat. Are you going to retain the OEM rear end (for parades or pulling stumps?) and tranny?
I went back in the thread and see that you say the DS is pre-loaded by an eighth of an inch. Is it possible that the slip joint has been over-greased, and simply can't compress enough? I've heard of people pumping in grease until it becomes a hydraulic cylinder, and first time a good bump is hit, it blows the tranny mount or the splines apart. Easy enough to pull the spline apart and clean it out. It only needs to be lightly greased.
#29
Ross, I'll pull the grease zerk out and see if it will compress any more.
Chuck, I checked the dimensions and everything looks to be normal (tape measure accuracy) except for the wheel base being roughly 3/4" to 1" too short. The frame does not appear to have been altered, the spring mounts look to be stock and the trans cross member appears to be stock. The wheelbase difference could be related to the front or rear axle placement. I do not know what is original on this truck and what might have been changed. The rear springs appear to be 'stock' using Fatfenders measurements. The consensus is that the trans is the stock type trans and the trans mount is not a factor. It bothers me that the wheel looks too far forward in the fender opening which leads me to believe that the wheelbase error is because the axle is too far forward in the chassis. It will be great for you to take a look over things when you are here with Gary. You've certainly spent way more time around these trucks than I have.
#30
