ID This Trans
#33
Mystery solved. Well enough that I am comfortable. With the truck in the air and the axle hanging the driveshaft is in compression. With the weight on the tires and the springs compressed the rear slip yoke is about 1/4" to 3/8" away from bottoming out the slip joint. I must admit that I did not expect the rear to move that much on the springs. I'd prefer another 1/4" or so of clearance but unless I get the truck airborne I think I am probably OK.
#34
I don't see how that's possible. With the axle hanging, it has to be 3-4" down from where it is when loaded. How could the DS be compressed then, but free when it's up? When the springs are compressed, the axle moves backwards some, but stock springs aren't exactly flexible. What springs do you have? Is this truck lowered?
#35
ABH
09-08-2018 03:48 PM
hayman68
06-25-2014 03:42 PM
ford1940deluxe
08-05-2007 11:25 PM
