'54 Heater Control Valve
11-22-2015, 06:07 PM
on
Did a search but just found old threads.
What are you guys using as a replacement the heater control valve?
11-22-2015, 07:27 PM
11-22-2015, 09:40 PM
on
So how did you mount it?
11-23-2015, 03:03 AM
Cut the hose, clamp it in, attach control cable
11-23-2015, 06:46 AM
on
I was thinking I needed to reuse the old firewall bracket.
Plus the inlet and outlet are inline,not like stock.
11-23-2015, 07:51 AM
If you want to stay stock you'll have to get the stock valve. If you're looking for an inexpensive replacement this will work.
11-23-2015, 08:57 AM
They make a version of what Cbeav posted with a small bracket. Easy to neatly mount to a fenderwell. Still has an old appearance. You gotta pay the money to keep everything 100% stock appearing.
11-23-2015, 08:07 PM
on
Stock would be nice but hard to find and too expensive.
This is not a full restore truck project anyway.
The stock heater hose is not inline with the napa type valve.
The stock cable routing will not work well either.
I think I found a couple on Ebay that I can make work.
Thanks.
11-24-2015, 07:19 PM
Let us know what you end up with and a picture would be good. I need one also. Same truck, 223 six.
11-24-2015, 07:35 PM
on
This is the what I'm going to use.Heater Valve 4 Seasons 74637
I saw it on ebay and ordered it from Rockauto.$26
The inlet and outlet are almost the same as the stock one.
I will have to fab a bracket and cable mount.Also will have to put a pin in the arm for the stock cable.
11-24-2015, 10:54 PM
Is the heater control valve still needed with Vintage Air A/C unit or can it be eliminated? I have one that's leaking.
Oakroadjoe
01-24-2009 12:05 PM
frty7ford
15
03-25-2007 06:29 PM
HENDEL JR
12-15-2005 09:01 PM
e william
01-30-2004 05:06 PM
elstx
01-16-2004 06:20 AM
