1997 F350 351w auto swap to 89 302fi
Hey trying to put a 89 302 fi that was mated to m50d into a 97 f350 351w auto e40d I want to use the e40d cause the m50d is weak. The problem is the 97 had another motor put in when previous owner used it and they hacked the harness with same color wires and terminals as plugs he put another 351 from a van in it. I want to splice the plug from 97 after fuse box on to 89 harness and find above 92 ecu that's a 302 with auto unless I can use 89 ecu. The 97 harness to hacked and there's more stuff on it than 89 plus distribuator plug is different please help
Budget
Trucks got couple years left on body got truck for 300 for axle but wanna hv something to plow and is 4x4 plus I can't find 351 under 500 plus I got 302 its free just time and maybe 100 bucks to do thanks I was thinking that about finding a harness but I might consider1993 300 6 since it has. Plug that will fit and I think more tourque than 302 but did they offer e40d with 6
I wanted to find the wiring diagrams for the 89 302 and 97 351 I don't see How the next style harness is any different except plugs unless wire colors are different they still do same thing unless I hv to use bare 302 and put sensors from 97 I want to splice plug on from 97 harness onto 89 motor please help I know it's easy to get plug but I don't have 170 dollars to spend on wires on top of a ecu
no im an engineer but i do need to communicate with other people all the time and even when its not quite as convenient it always seems to work better if i communicate in a way thats easier for them to understand its not that i was picking on you before i am now of course but before i was trying to give you helpful advice as to why maybe you werent getting many responses and even cell phones have punctuation its not as easy for you of course but it is easier for whoever is trying to read it
WHAT IF I USE A MANUAL TRANSMISSION
I might use a m5od because I have everything New flywheel 5 years ago along with New clutch but stupid slave cylinder went again 5 year's later is the wiring have close enough to match colors after fuze box I know the 97 has transmission wires but if I use manual I don't need that plus my states don't do emissions for 3-4 ton use the 302 computer to
I would like to but i will need a flexplate flywheel computer and idk if splicing harness will work
Harness is shot on 97 missing stuff been cut spliced 89 harness. Is complete distriburator plug is different from 89 to 95 so it would hv to be spliced
