Missing or stuttering under load.
Old 11-22-2015, 03:13 PM
iverger's Avatar
iverger
iverger is offline
Recently installed a TS6 with stock tunes. First thing I noticed was a miss or stutter at lower RPMs if I put my foot into it all at once. I have a fuel pressure gauge and noticed it was dropping to 40ish PSI from 60ish in an instant which it never did before. Before the chip it was more gradual. Based on that I decided to replace the fuel pump, filter and clean the screen. Just to make sure I had a good fuel feed. However, none of that helped.
Something else worth noting is that I've never been able to produce much smoke. I don't really want to because it is a waste of fuel, but if I put the TS6 in 70 or 100hp modes I figure it should produce something, which to me is an indicator that something else is not right yet.
I'm looking for pointers? I have Fuel Pressure, Oil Temp, EGT and Boost guages. I also have a Torque Pro setup with standard PIDs available.
Maybe I need to remove the chip all together and see if the stutter goes away. Maybe I didn't clean or over-cleaned the pins......I dunno. Guess I should call the chip seller and see what they have to say too.
Thoughts?
Thanks,
Bob
Old 11-22-2015, 03:59 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
I would definitely pull the chip and see if it goes away.
dcelrod
09-23-2015 10:14 AM
Jeepincj7
12-24-2011 03:47 PM
99 7.3 towrig
11-11-2010 07:01 AM
FTE Herman
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
51
05-20-2005 01:34 AM
Mizzou
Computer Chips & Tuners
02-24-2003 05:19 PM
Quick Reply: Missing or stuttering under load.
