'66 High hump ? Low hump?
Old 11-21-2015, 04:08 PM
john jamieson's Avatar
john jamieson
john jamieson is offline
I want to order a floor mat for my F100 3 on the tree. The hump is about 5 " tall. It's the same as the hump in my '64 with a 4 speed. Is it a high or low hump?
Thanks. john
Old 11-21-2015, 04:23 PM
jowilker's Avatar
jowilker
jowilker is offline
John I believe that would be a low hump. The high hump would be the floor shift that does indeed have a higher hump.
John
Old 11-21-2015, 06:28 PM
daveengelson's Avatar
daveengelson
daveengelson is offline
John: John is correct, the hump in the picture would be considered a 'low hump'. My 65 with the 3 speed on the column is a 'low hump' floor pan. My 65 with the T18 4speed on the floor is considered a 'high hump' floor pan.
I selected the carpet color but before installing went to an upholstery shop for estimate and found they went thru the same supplier and able to get it for less, they applied their discount to their installation. I prepped by laying down insulation and basically all the upholstery shop did was apply a coat of contact cement, sections at a time, and lay down the carpet, fit like a globe. The shop was also able to apply their discount thru same supplier for the upholstery.
Old 11-22-2015, 10:49 AM
6t6merc's Avatar
6t6merc
6t6merc is offline
I don't think there is a high hump or low hump floor. The "high hump" is created by cutting the floor and adding the sheetmetal trans cover. Yes?
Eric
Old 11-22-2015, 11:08 AM
john jamieson
Thanks for the replies. The humps have me a little confused unless they really changed things from '64 to '65. My '64 f250 has the 4 speed floor shift. The hump is bolted on and is the same height as the welded hump seen in the picture. I have seen floor mats and carpets listed for 2wd auto trans or high hump floor shift/4wd. I assume that the 2wd auto trans mats would work for 2wd column shift 3spd but maybe that is a bad assumption.
john
Old 11-22-2015, 11:39 AM
daveengelson
Believe the difference is possibly with the type tranny, my 65 with the T18, seem to recall the shifter housing sets slightly above standard floor pan and it came with the original 'high hump' cover. My other 65, with the 3 on the column, appears same as the floor pan in the picture with no attached cover.
Not a good pic, and difficult to determine with the carpet installed, is a pic of the 65 with the T18.
https://www.ford-trucks.com/user_gal...150706.520.390
Old 11-22-2015, 03:38 PM
6t6merc's Avatar
6t6merc
6t6merc is offline
john
Your assumption is correct John. The hump would be the same with 3-spd or Cruiso except the auto truck requires that small rectangle to be cut out for access to the band adjuster.
Eric
Old 11-23-2015, 12:09 PM
svolpone's Avatar
svolpone
svolpone is offline
i have a mat that goes across a hump that you can have. it's black rubber. Not new, but free for the cost of shipping. i put in a shifter and it doesn't work for me now. i'd hate to throw it out. it's in pretty good shape. let me know and i can measure it for you, and take a picture.
Old 11-23-2015, 08:47 PM
john jamieson
Steve, Thanks for the generous offer. I can definitly put the mat to good use. Both my '66 and '64 need mats. The '66 doesn't have one and the '64 has a partial one that I can't even use far a pattern. Let me know how much and where to send it.
john
Old 11-24-2015, 10:34 AM
TA455HO's Avatar
TA455HO
TA455HO is offline
Eric
I removed the factory carpets and foam padding in my truck this past weekend and saw that area was cutout on mine but not on John's truck and wondered what they were accessing on the tranny. The little rectangle plate that covers the hole is form fitted. And mine was under the foam and carpet so must have been something they did at the factory. Good info....
Old 11-24-2015, 11:27 AM
ihcc104's Avatar
ihcc104
ihcc104 is offline
Hey guys I am in a corner here.... I have a F350 1964 2x4.... it is an automatic so technically a column shift... is this a big hump or a small hump. For 350's they only list high hump with manual trans, but I have an automatic which I am sure isn't very common.
I am looking at the MIP Vinyl floors
Truck Parts and Truck Accessories
I think 49-5906 is the one I need but not sure.
Thanks for any help.
Old 11-24-2015, 12:51 PM
6t6merc's Avatar
6t6merc
6t6merc is offline
I'll say that any slick that has had the floor cut and a trans cover installed is a "high hump" but I've never seen your combination before, Cory.
Eric
Old 11-24-2015, 03:39 PM
ihcc104's Avatar
ihcc104
ihcc104 is offline
Eric
Thats what I thought but the "hump" on the OPs post, doesnt look much higher than mine and John called that a low hump
Old 11-24-2015, 03:54 PM
6t6merc's Avatar
6t6merc
6t6merc is offline
Mine was a "low hump" 3 on the tree, like John's in post #1, until I cut the floor, added a 4-spd and a cover and made it a "high hump". So I'll be buying a carpet for a "high hump".
Eric
Old 11-24-2015, 03:59 PM
ihcc104's Avatar
ihcc104
ihcc104 is offline
Eric
Hmmm... well let me know how the high hump road goes for you. I also wonder if there is a difference in humps between the 61-64 and the 65-66 truck cabs,.
Quick Reply: '66 High hump ? Low hump?
