Ford Changed 6.2L Oil Spec to 5w/30 for MY 2016
5W30 is just a slightly thicker oil that would give some additional protection. It sounds like Ford might be going back to the 10W-40 days. When I was growing up dad would change the oil in the driveway. Every 3000 miles. In the summer months, it was 10W40. In the Winter months it was 10W30. Anything else was sacrilage. This was true into the 2000s. When I had a Explorer it required a 5W30 that was "This cannot be correct" in his book. Now even he uses 5W30 for everything except on vehicle which still gets 10W-XX Now when I worked for a local telecom company, it was 15W40 in everything gas or diesel. You got an oil change once every 6 months.
At work, I just changed the oil in the work van (E250 with a 4.6 V8) with MC syn blend 5W20. However, I would consider using a 5W-30 or due to the wear on the engine and the condition the engine is used in "i.e. towing and delivery vehicle". While performing the oil service, the boss asked me the best realistic practice. I said not like my last company, too long between. Going every 5K is going to increase downtime and create scheduling issues for servicing. I said once every 4 months with a regular oil checks once a week should keep the engine happy with oil. We know we have been burning oil. Now we keep some on hand when it gets checked.
IMO, 5W30 would offer better protection to the engine and should be modified to the climate.
I suggest doing some research on the "bob is the oil guy" forums and educate yourselfs further. Lots of good info.
I have No idea Why Ford changed.
could be 5w20 is going away...
after millions of miles.. Ford seen something and wanted the change.
wear OR weather/temperature related.
https://answers.yahoo.com/question/i...6091126AAtqEN4
http://www.machinerylubrication.com/Read/518/motor-oils
Look at the specs on the 5w30 oil they want. Is it synthetic now, when the previous spec was semi-synth or dino could be used?
My Taurus with the 3.5L Ecoboost takes 5w30 semi-synth, and I use full synth Mobil 1 in it.
I suspect that they are just switching everything over to the 5w30 that my Taurus calls for as a cost-saving measure for factories and dealers.
This is like when I got my V10 - previous year used 5w30, mine said 5w20 - I stuck with 5w30
