Depressurizing fuel system?
Old 11-21-2015, 12:51 PM
Frdtrkrul's Avatar
Frdtrkrul
Frdtrkrul is offline
I'm changing the fuel filter on the old truck and I am not sure if I have to switch off the inertia switch behind the passenger side kick panel and depressurize the system or if I can just pop the filter off and pop the new one in. I've read several threads but no one ever says it. Only place I have seen it is on this video
Main reason I'm doing the filter is I am having stalling issues when I first start up some days. But I found out that its probably the butterfly valve that is gummed up probably and the fact that far as I know my dad has never replaced the filter in the years we've had it (supposed to be done every 15K miles) so...yeah.
Old 11-21-2015, 02:18 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Nothing to worry much about.
Go to the fuel rail test port and bleed the pressure off.
You will get gas running out the lines anyways until the local area clears of it's volume.
Then remove the large air hose from the throttle body, spray clean the throttle body inside and the plate until it runs out clean.
Next remove the Intake Air Control and clean the intake air control valve being sure the internal slide valve moves freely.
Good luck.
Jbotto
08-22-2017 01:44 PM
wildstang
10-10-2008 03:01 PM
55mercury
General Automotive Discussion
10-12-2005 10:52 AM
larryf100
09-23-2004 09:08 PM
barney
1983 - 2012 Ranger & B-Series
05-14-2000 02:20 PM
Quick Reply: Depressurizing fuel system?
