Speedo problem giving me trouble
I'm hoping to gain some insights. The speedometer gauge has been jumping 10-20 mph, and sometimes while driving about 60 will hold steadily around 70. I installed a new cable without change then swapped in a spare gauge with no improvement. Cable routing is good with no sharp bends. Could the problem be in the driven gear that attaches to the transfer case? It's plastic teeth that go inside the transfer case actually look good, but can the female end that the cable fits into go bad?
That's a good point and yes the cruise control is steady. Is there any way the cable side of the gear could become stripped and cause the jumping I'm seeing in the gauge? From what I understand jumping is caused by the cable binding then snapping loose, so I wouldn't think so, but I've tried most everything else.
Do you guys typically grease a new cable before installing? I've experimented with a variety of lubricants over the years but haven't had good luck with any of them. Researching them online there seem to be as many opinions as posts. I did grease this new cable so assume that could be suspect too...
lavatan
12-29-2011 12:53 PM
brucewon
03-23-2010 08:07 PM
gingerbreadmaniac
09-03-2004 10:48 PM
redneckdieselmechanic
15
01-05-2002 10:54 AM
