engine compartment heat
on
can anyone give me an estimate or even a CWAG guess what the temperature under the hood of a '50's f-100 with a big block, headers, air conditioning, etc might be in the summertime... in the South or maybe West...
I'm figuring 300° or better... anyone ?? anyone ???
this is a serious question...really
j
j
on
reason I'm asking... looking at some alternative coatings over the inside of the flip front... instead of filler and primer... found a product... a UV cured resin that is used on surfboards....
I need to talk intelligently to the vendor about air flow and under hood temps for him to recommend a compatible product... they have several that MIGHT work and wanting to find the best application... if this works like advertised it would do away with a lot of the grunt work and give a nice smooth paintable finish... at least with less work...
j
j
I had not heard the term "heat soak" that Ross used. I looked it up and thought I'd share an article in case someone else out there hadn't heard either.
Thanks!
http://cjbfire.com/Heatsoak.pdf
Thanks!
PAJARONEGRO
1999 to 2016 Super Duty
09-05-2015 08:14 PM
