2015 5.0L xmission downshift
I notice when I accellerate in auto my screen will show the xmission go from 1st to 2nd to 3rd etc. all thru 6, but when I decellerate it goes sequentialy from 6th to 3rd, but then skips 2nd and goes straight to 1st right before I stop. It never goes into 2nd when coming to stop. It does upshift/downshift in the manual mode with no problem. Am I missing something or need to go into the settings again. I see no setting to only delete 2nd gear on the downshift when in auto, so I don't think I accidently did any setting change. This could all be normal also...whadaya' think?
But I'll watch my truck and check.
I saw there was no "setting" per say in the inst cluster settings that allows you to lockout 2nd gear... but when you engage the PRS system, you effectively are putting settings into the xmission. This allows you to lock out any gear you don't want under certain conditions. I wanted to make sure I didn't accidently delete 2nd gear (or at least on downshift, since like I said, it reads 2nd on the upshift)...but it appears to go back to default when you go into park. With the PRS still engaged and reselecting the gears you deleted when the PRS was engaged you put the "settings" back, thus having all 6 gears again...thnx for all the input...
The part you're missing is that P stands for Progressive in PRS. You can't remove any gear you like from the shift pattern, the lockout starts from the top down. You can lock out 6th gear, 6th and 5th, so on and so forth. You can't lock out 2 without also locking out 3, 4, 5, and 6.
You would redline before 35 MPH in this condition. This is the only way you'd lock out second gear.
I just bought my 2015 XLT 5.0 this last Friday. I did not notice the transmission downshifting in auto, skip 2nd gear, going on to 1st gear on the screen before stopping. I was not paying attention to the screen. I'll keep a eye on the screen tomrrow when i drive, and watch the down shift.
Thanks for the input.
Scott
Scott
joegeds
16
01-18-2015 07:29 AM
TheKid1
6.7L Power Stroke Diesel
11-16-2011 10:53 AM
joshsombo
02-14-2006 12:32 AM
