i am building a new engine for my 6/77 F-250 4x4. i have been told the 400 2wd oil pan is the same as a 4wd oil pan. does anybody know if thats true ? i found a 81 400 2wd in a wrecking yard today but didnt wanna pull the pan until i had confirmation.
thanks, chris
correct on the sump location, sorry forgot to mention that. but the pan i found is in fact a rear sump, just in a 2wd chassis. was hoping it would work in my 4wd application
I think starting in 80 there all rear sumps. My 86 2 wd had a rear sump pan it was a 351w though. It should work.Id grab the pick up tube for the pan your getting.
