1993 F-150 4X4 Towing capacity??
My dad has a 1993 F-150 4X4, reg cab, long bed truck with a 5.0L, AOD and 3.55 gears. He is thinking about towing my truck on a trailer to my new place when I get back from Korea. Together the truck and trailer are going to weigh about 5,000lbs. I would hate to see him burn up the tranny. What is the max towing capacity for this truck? Thanks
Should be no problem. Are you sure it is an AOD and not an E4OD? My '94 has the latter.
GCWR = 10,000
Unladen weight = 4425
driver and passenger = 300?
30 gallons gas = 90
max trailer weight = 5185
Assuming no load in bed of truck
The GCWR is my low-end guess. I'll check the manual at lunch.
Jim
GCWR = 10,000
30 gallons gas = 90
Jim
Update from the owners manual:
GCWR = 11,500
The 10,000 lb figure is for the 4.9L engine.
7000 is the listed maximum trailer weight.
Corrected fuel weight:
30 X 6 = 180
BTW, the unladen weight is from the California registration card. This is based on what Ford tells them when the vehicle is delivered new. Our fees are partly based on that number. Those in other states probably do not have this information.
Jim
GCWR = 11,500
30 X 6 = 180
Jim
aaroncarn
02-11-2012 08:40 AM
wackypacky
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
07-07-2004 09:55 PM
fttahmas
01-17-2004 10:22 PM
doccherry
09-26-2002 05:08 AM
mickey mouse
Fifth Wheel & Gooseneck RV Towing
04-16-2002 07:40 AM
