My truck broke.
You might try changing just the boot/spring - NAPA 702418 or Dorman 49812.
The boot/springs are under $8.
Pull the COP and check for a rusty spring, splits in the boot or cracks in the coil housing.
Also, if the misfire code does not move you may have a:
bad fuel injector
broken wire in the COP connector cable
broken wire in the fuel injector cable
Blow out the plug hole with compressed air and pull the coil/boot off to see if there is any water in it.
I had rain water dripping from the panel at the base of the windshield causing misfires on #6 & #7 in an Exped.
Sometimes got a code, sometimes not.
Fixed the drip, dried out the plug holes and my problem was gone.
COP boots are a heckuva lot cheaper than the whole coil.
Stewart
Pulled the COP and it was not just dripping wet, but also had mud, rust, and dirt. Cleaned that out and cleaned up the coil pack, but sadly that didn't fix it. Pulled the plug and cleaned it, and put it in #2, and put the coil pack in #2, and put the plug and pack from #2 in #10. #2 started to misfire.
My father had stopped by when I started it, and he said it's running fine. I could still feel the misfire so I plugged the computer in and saw #2 code. He said anyone else in the world wouldn't be able to feel that, as it was pretty subtle when you have 9 cylinders that are running fine.
Reluctantly replaced the coil pack and fired it up, and my issues were no more. Held on to the coil pack just in case. #10 was pretty easy to get to compared to #8 on my v8 expedition years back.
All is back together and all is well.
Glad to here you got it sorted out
Ford released a TSB quite a few years back, advising dealer techs to NOT replace COPs because of a misfire without testing them, because of all the COPs they got back and inspected, some huge amount were not bad, something like 80 or 90% of them.
Be that as it may, you fixed the problem with a new COP. Carry on
Splash67
09-17-2018 04:57 AM
Dustin198820
03-12-2009 09:29 PM
