Steering Column Compatability
Hey BJ,
We went the cheap route first & bought a knockoff column.
The parts that look metal are actually just chrome plated cheap plastic.
It just fell apart trying to install it. We then went with an Ididit column - much better. The paintable ones aren't that expensive.
Good luck over there.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Greetings to all- just did rough-in of ’75 F-100, automatic column into my ’56. Biggest obstacle was shifter lower arm was inside cab about 1".
However, I had already planned to relocate my Series 400 gearbox (Toyota clone), forward 1-1/4" on frame rail.
Two reasons: First- moving frt axle/strng lnkg forward 1-1/4" & can now use stock drag link; Second- want column/wheel to tilt back toward driver a little more.
Lower shifter arm is now out of cab- barely.
Also, had to graft a ¾" –30 spline female (from donor rag joint with Series 400 kit) onto the ’75 rag joint which was ¾" –36 spline. Top portion of ’75 rag joint was swedged onto shaft. More than one way to skin that cat.
I fabed my own brake pedal brace/hanger, knawed around to fit ’75 pedal & managed to use stock '56 upper column brace/brkt where it mounts to lower part of dash panel. Used top set of holes on ’75 column mount piece. I’d be inclined next time to buy ready-made pedal brace/hanger.
I had to redo a few of the steps because of no ‘blueprints’ – took me about week & half. But I’m old & slow.
I’ll probably use ’75 strng whl- smaller dia., but ’56 one will fit right on shaft, but there’s a little gap to deal with between wheel & column bell.
I can give you some dimensions if I can. Good luck... john
DillonZ81ford
03-03-2011 02:27 PM
fatfenders
18
09-18-2003 09:15 PM
