Read my 5.8s spark plugs! -Pics
Wanted to post this here for all you small block experts... 190kish on engine, finally got these out after lots of soaking and a 30'' breaker bar or they would have been changed a long time ago.
Please let me know if you see any issues I should be aware of, thanks!
I see nothing wrong with those plugs other then they are very worn out. A fresh set of plugs of the correct type of either Motorcraft or Autolite brand will do fine.
The plugs do look like there is some oil burning but not so much that they are black or worse, wet! They look good for an engine with 190K miles on it.
We had one of the Champion Spark Plug cleaners at work, and when we recently were cleaning out old stuff it went to the junk. Well I think someone rescued it for home.
I used to clean plugs regularly when I was driving old cars that would foul them pretty quickly. The 18mm plugs work pretty well, but the smaller 14mm ones can be tricky to get all the beads out of the narrow crevice.
