Hit and Miss
Hit and Miss
I have a rebuilt carb (original) I just put on my 54 truck 239 v8 and it idles good but the second I try to give it gas it bogs down and almost dies. I can pull choke out about 1/2 the way getting the rpms up and when I hit the gas it doesn't bog down at all. Does anyone have any thoughts. I have tried adjusting the screws but still at idle or lower rpms it bogs down real bad.
You are getting a lot of good solutions here. I had a similar problem. My truck would bog down and or backfire at high revs. I messed with my carb, my fuel pump, fuel lines and so on for almost a year.
It turns out my distributor was shot. The breaker plate wobbled and the shaft was worn. I bought a good 54 dizzy from Pinto Plumber, Dennis, and that solved my problem. I guess my 60 year old dizzy just wore out.
Good luck chasing down your problem. Keep us posted.
Just to tag on to what Abe said, your problems sound a lot like mine, and I received some of the same advice from the experts here. My truck is "stuck" in a body shop right now, and I haven't been able to try any of the suggestions yet. I will be following your thread to see if and how your problems are resolved.
Jim
Deerbrook, WI
Jim
Deerbrook, WI
Tofudude
08-25-2012 05:50 AM
EvoDawg
03-27-2012 07:06 PM
79str8six
03-08-2011 08:47 AM
