Strange Codes...
Strange Codes...
Evening all. I ran a KOER test on the 302 I recently installed in the truck and got some strange codes, some of which are because I botched the power steering & throttle tests, but I can't make heads or tails of the others. Here they are...
40(?), 10(?), 44(thermactor inoperative), 60(?), 77(user error), 208(?), 33(EGR not opening), 77(user error), 52(power steering switch open)
I know 10 is usually a place holder that I've seen before on the other system. Can anyone shed some light on the mystery codes?
Thanks!
Thanks!
I believe the user error code can be from not blipping the throttle at the correct moment to test the MAP sensor...
But considering that there are NO codes that should end in zero, AND your are getting both two and three digit codes... ECM? You might try one of those code readers to eliminate human error from counting flashes.
plus, you could pull the ecm and just check the capacitors. Would only cost you time.
dongreene
02-20-2006 07:54 AM
bkampbel
10-07-2005 04:53 PM
