1994 F350 Help With Paint
Old 11-17-2015, 05:56 PM
gailahan's Avatar
gailahan
gailahan is offline
I have a 1994 F350 and I'm trying to figure out what the paint colors are so I can repaint it. It does not have any Ford stickers around the door, but it has a Crown Coaches sticker that says CC# 7039. I think that might be a color code but I'm not sure and I'm not finding anything on the net. I attached a picture of the truck to this post. I think the top is either Reef Blue or Cayman Green. I'm not sure about the bottom tan color. Thanks for the help!
Old 11-17-2015, 06:06 PM
F1snob's Avatar
F1snob
F1snob is offline
4wd Low
Do you have the ID plate (not sure the specific name) on the drivers door jam? There are color codes on there. You can also put your VIN number in the VIN Decoder under Tools above on the Ford Truck Enthusiast site and it will give you the color codes. Worked perfect for me.
Hope that helps!
Old 11-17-2015, 07:10 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I highly doubt you will find the bottom paint code since it is aftermarket
You may be able to do a vin decoder to get the green color but they are not always right
Old 11-17-2015, 07:20 PM
Bird-Dog 250's Avatar
Bird-Dog 250
Bird-Dog 250 is offline
Go to a auto body shop supply that does a major paint business. They should be able to match the color and you'll have the color name and paint code.
koch26
10-31-2011 09:56 AM
Khauler
09-05-2011 06:08 PM
Kautrey
02-22-2011 09:55 AM
66 blue oval
03-21-2007 12:13 PM
Quick Reply: 1994 F350 Help With Paint
