First rear end question - Slight play in Pinion (can turn pinion yoke slightly before engaging)
I've got a spare axle on the bench I'm working on (new brakes, new bearings, blast/paint etc).
Tonight I noticed that there is what feels like a slight amount of play in the Pinion. Specifically I can turn the Pinion yoke a little bit before feeling/hearing it engage (presumably with the Ring).
The cover is gasketed on currently to keep sand/paint out while cleaning up so haven't looked inside yet, but is some small amount of play ok?
EDIT: When I had the cover off, the gear wear pattern on the ring looked ok to my laymans eyes (could see the pattern from where oil was wiped away when hand turning it).
So I guess what I'm feeling here is the ring backlash and I'll have to test it when I get the cover off?
Per the FSM looks like it needs to be less than .1mm (.004")
Everything else looked great on the wheel end save for one blown seal. Bearings and bearing surfaces looked great as did the axle splines. Same with the Ring teeth.
Debating on just measuring backlash and buttoning up or ripping out all the diff internals and having someone put in the OX locker for me along with new bearings/seals. For a daily driver that sees limited mileage, my perfectionist nature is fighting with my sense of reason.
redrivergorge
07-06-2015 04:35 PM
Katmandu
1978 - 1996 Big Bronco
11-09-2005 01:45 PM
therigwelder
05-27-2005 07:24 AM
gatesj
11-19-2004 09:49 AM
