DEF FLUID
DEF FLUID
Here's a little pointer if ya wanna save money.
DEF fluid is basically ammonia.
So .... If you use one gallon of ammonia to 1-1/2 gallons of distilled water mix it's the same thing.
Never had any problems with def contamination 👍
It will save you money. Dollar tree for the ammonia and a grocery store usually sells distilled water around 88 cents a gallon which would cost around $2.70 as opposed to $9-$16 at the truck stops or farm stores
DEF is actually made of 32% urea and 68% de-ionized water. So right off the bat it's not distilled water, it's de-ionized.
Second, urea is not straight ammonia. It is synthesized from a chemical process of ammonia and carbon dioxide.
I'm all for saving money, but this is not one of them.
these new trucks/powertrains are not like those of old where adding tranny fluid to the oil to quiet lifters, and burning used oil as fuel, or adding some gas/kerosene to the diesel in the wintertime, etc are things that used to work in the old days. These new machines are operating a much smaller tolerances, and as you know failures add up quickly.
Unfortunately, this will not work and owners should not try this because it will result in DEF system failure.
def
I didn't know they sold it. But I had bad fuel from Murphy USA in Effingham Illinois... Insurance covers it but it's $9K to repair it 😲... I might go back to the def fluid. Never had any problems with the distilled water and ammonia mix though for 20K miles
