It has potential if you just rid it of the upper sheet metal, looks as though the frame and drive train is done well. If it comes with a title all one would need is a body and proper box.
You guys really need to work on your tolerance. This builder is visionary as evidenced by the sensible mods. I see this as an extension of Ford's timeless design, with some notable improvements that address critical engineering weaknesses.
-junk Ford engine is thankfully gone!
-annoying window fuzzy issues completely solved
-unnecessary curves removed, you could block this thing out and paint it in a day!
I could go on but I have some block sanding to do. I'm just a little bit disappointed in my FTE forum friends right now.
