Modifying a M90 supercharger?
I've got this supercharged 3800 series II engine out of my Bonneville just sitting here. I got to thinking today if it would be possible to modify it to work on my 300?
As you can see its designed to be mounted on the intake manifold. I thought I could build an adapter to bolt to where the manifold would be, then into a pipe running to the carb.
I don't remember exactly how much boost these chargers make but I believe it to be about 6psi.
- Is this possible?
- Would having an adapter into a pipe further increase boost? (I don't want to have too much.)
- What CFM do you think would be necessary to support around 6psi boost?
- Is this possible?
Either stop that **** or go away.
ExPACamper
162
03-07-2018 08:09 AM
snaponprofile
41
10-28-2011 08:27 AM
