Head gaskets on 7.3
Head gaskets on 7.3
I'm putting a 7.3 in my 86 f250. I had the heads replaced due to cracks in the original. Head gaskets seem pretty straight forward except that I've seen multiple torque specs listed. I've heard 85 100 110. Also I was wondering if it was possible to reuse the intake gasket. I bought a fel pro head gasket set. Did not include it. I was having some cooling system issues when I pulled it from my 90. I was relieved when it was the cracked heads. The cylinder walls are clean. No cavitation. Has a little ridge but hey for 260xxx miles 415 psi compression isn't bad. And the newly ground valves should help that.
wiccantoy
12-18-2007 07:30 AM
