2005 Expedition PCV with Wires?
No, the PVC valve is at the top of the engine and has a splash guard under it. While it's possible for oil vapors to get into the PVC valve and cause build-up over 10s of thousand of miles, it's not going to suck down a quart every 1,000 miles. For you to lose a quart that often it's more likely worn valve guides and seals or worn piston rings.
TIA
Tim
g3ride69
03-24-2016 05:56 PM
